11-23-2023 11:46
11-23-2023 11:46
I upgraded from Fitbit Charge 5 to Fitbit Charge 6, but I don't see the map of the route for my walks anymore in the Fitbit app on my iPhone. I can see my older activities using Charge 5 still have the map of the route in the app. I checked that the Location is "Always on" in the settings for the app on the iPhone and the Charge 6 is set to "Dynamic" under the GPS setting. How do I fix it so the Fitbit is tracking my walks on the map with Charge 6? Any help would be appreciated.
Thanks,
11-29-2023 05:13
11-29-2023 05:13
I'd be interested to know as I'm having the exact same issue!
11-29-2023 05:49
11-29-2023 05:49
@willckho make sure the GPS is on for Walk activity in the activity settings (not quite sure but it may be off by default):
I found the Dynamic and Built-In GPS modes very poor and eventually, I started using Phone mode. Dynamic and Built-In could acquire GPS signal but then disconnected for some reason and the watch has given up trying to reconnect. I tried several times and no success so I fell back to 'Phone' mode.
11-29-2023 10:15
11-29-2023 10:15
Thank you so much, I think you may have solved my issue. I'd switched between all modes and it still hadn't worked so checked this setting and it was off. Thank you!
Best Answer11-29-2023 10:41
11-29-2023 10:41
Thanks that worked!
Best Answer11-29-2023 13:42
11-29-2023 13:42
I'm having the same problem. I recently bought the Charge 6 and don't get the map of my walks like I used to. I always carry my IPhone with me.
Best Answer11-29-2023 13:46
11-29-2023 13:46
thanks! I checked and my GPS setting was OFF. Hope that makes it work next time I exercise!
Best Answer11-30-2023 07:32
11-30-2023 07:32
Best Answer12-27-2023 01:25
12-27-2023 01:25
Thanks for the tip. Went for a walk after doing this and it missed the first part of my walk on the map. Any ideas? Was only a short walk to test it haha
Best Answer12-28-2023 10:53
12-28-2023 10:53
