08-14-2024
06:39
09:02
LizzyFitbit
08-14-2024
06:39
09:02
LizzyFitbit
When I exercise the daily exercise is recorded, but the heart rate show as a time rather than bpm? My wife also has a fitbit and we compared the results but hers shows the activity and bpm in the heart graph, mine shows the average bpm but when you run your finger over the zones it does not show the bpm it shows as a time field which is completely useless as i wish to monitor heart rate while exercising. Can you help with the settings for this?
Best Answer08-14-2024 08:33
08-14-2024 08:33
This was a bug in the app, if I recall correctly, that was fixed some time ago. Update the app.
Best Answer08-14-2024 09:07
08-14-2024 09:07
That’s good, how do you update the app?
Best Answer08-15-2024 17:14
08-15-2024 17:14
Hello @FinedonRog
To check for an app update, go to the Google Play store (Android) / Apple app store (iOS) and look for the Fitbit app. It will let you know if there's an app update available for you to download & install.
