02-17-2024
22:00
04:50
CrisVillaFitbit
02-17-2024
22:00
04:50
CrisVillaFitbit
The device is 2 months old.
So far it has lasted 5-6 days. for a few days it goes 1-2 days on 1 charge. Settings are all the basic settings. I don't use GPS, always on display, screen wake-up is also manual.
Moderator edit: edited title to clarity.
02-19-2024 04:53
02-19-2024 04:53
Welcome to the community, @Sobrijozska. Thanks for explaining your situation in regards to the battery of your Charge 6.
My best recommendation would be for you to check this article and follow the tips they have in there, please, follow them in the order they appear.
Let me know how the battery goes once you have completed them.
Best Answer02-19-2024 08:01
02-19-2024 08:01
There are basic settings, no extra functions are activated. I have already looked through these tips over the weekend, that's why I reported the problem.
Best Answer02-19-2024 08:04
02-19-2024 08:04
I did several restarts while charging.
Best Answer02-19-2024 10:47
02-19-2024 10:47
Hello @Sobrijozska
Since you've already tried the recommended troubleshooting steps without success, it sounds like you might have a defective device. You probably should contact Fitbit support (<-- click link).
Best Answer02-22-2024 11:57
02-22-2024 11:57
what can support do?
Nothing. I believe that it must be charged every day.
Best Answer02-22-2024 13:31
02-22-2024 13:31
Hello @Sobrijozska
If Support confirms that your device is defective, they will let you know what are your options under warranty.
Best Answer02-24-2024 12:11
02-24-2024 12:11
Thanks for all the help. it will be a warranty replacement.
02-24-2024 13:31
02-24-2024 13:31
Hi @Sobrijozska
Thanks for letting us know that you are getting a warranty replacement. Glad to see that support was able to help you.
