01-30-2024
06:09
05:19
CrisVillaFitbit
01-30-2024
06:09
05:19
CrisVillaFitbit
The resting heart rate has registered 62 for the past three weeks and has not changed. I've reset the fitbit and still no change.
Moderator edit: edited title to clarity
Best Answer01-31-2024 05:27
01-31-2024 05:27
Hi and welcome to the community, @Peteyboy.
Thank you for explaining your situation in regards to the resting heart rate tracked in your Charge 6.
I was able to confirm, from the last sync, that your resting heart rate shows as 60. I also checked if everything was ok in your Charge 6 and it looks normal. If you think this is not ok, I recommend you to restart your Charge 6 once again and consult to your doctor about this, since everything is ok in our end.
You can check more information about the resting heart rate here.
Best Answer03-22-2024 02:30
03-22-2024 02:30
I have the same issue with my Charge 6. Resting Heart Rate 65 bpm for 12 days now. I tried swiping down as suggested to restart but cannot find Settings, down up or sideways!
What to do now?
PS Dashboard today says RHR was 66 not 65
