07-24-2024
09:43
13:48
LizzyFitbit
07-24-2024
09:43
13:48
LizzyFitbit
My Fitbit has been perfectly tracking any KM I’ve walked throughout the day. Since yesterday, it’s tracking my steps but showing 0.0km even after 8k steps.
I’ve not changed any settings and I have restarted the device a few times.
Help?
Best AnswerHello @TomiJ
There is currently a bug that is affecting distance tracking. The team is aware of the bug.
One user doing troubleshooting discovered that they were able to get distance tracking again when they turned off automatic stride and manually set a stride length in the Fitbit app. Unfortunately, we've seen that this workaround doesn't work for all users seeing this problem.
If you want to try this workaround as a temporary solution, this help article has the steps to manually set the stride length in the Fitbit app (<-- click link)
Hopefully, it won't take too long for a fix so we don't have to use a workaround.
Best AnswerAny update?
