05-13-2025
		18:20
		07:44
			FatimaFitbit
		05-13-2025
		18:20
		07:44
			FatimaFitbit
For anyone who's fed up with the random complete offline working outages of their fit bits here's something to look for. It's been several days since my Fit Bit charge 6 was actually working and tracking my activity. I tried all the usual things recommended and got zero reaction from my fit bit. I had it on the charger even though when it stopped working I still had juice according to the screen. It seems to be necessary to just take it off the charging cable and let the thing run completely out of juice before it will out of the blue show it is alive after all. I stopped using the Fit bit premium after frustration when it pulled this crap twice while I was actively working to reduce my weight and get my BP lowered. But today I decided to sign back in to it to look for forum input. Unexpectedly after I signed in I found the device was surprisingly alive. Coincidence? Who knows but anyhow when I gave it another try with the push of the side button ten minutes ago the screen lit up with the fit bit logo. It was showing only 4% power and now it's back on the charger again. So guessing the whole time it's been on the charger it wasn't helping. I find this stuff very frustrating as I like consistency as much as possible. So I guess I'll need to buy a back up fit bit to pick up the slack when the first one decides to crap out. So I'm sharing my experience for the rest of you who are experiencing the same thing for a device that isn't that old.
Moderator Edit: Formatting and clarified subject
05-15-2025 07:38
 Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              05-15-2025 07:38
Hi there @Jeephers!
It's great to see you here in the Fitbit Community!
Thank you so much for sharing with us the experience you're having with your Charge 6 which is not reacting to the resets and is not charging as expected. I want to thank you for all your efforts too.
Have you already checked if you can update your Charge 6? In case your Charge 6 has an update pending please follow the steps described here: How do I update my Fitbit device?
Do you see any damage on your charging cable?
Additionally, I suggest you follow the troubleshooting steps from this article too: Why isn't my Fitbit device's battery charging?
05-15-2025 09:01
05-15-2025 09:01
 Best Answer05-17-2025 14:14
                              05-17-2025 14:14
Hello @Jeephers
It's not often mentioned. You have the ability to submit your issues/comments using the Feedback option in the Fitbit app.
The team receives the Feedback reports for review.
 Best Answer08-13-2025 02:32
08-13-2025 02:32
I am 100% fed up with my Charge 6 and my Fitbit premium account. My Aria scale won't sync. My Charge 6 is patchy. I don't feel Premium is really helping. But disillusioned since my trust Charge 4 gave up 😞
