12-07-2023
19:24
12:53
LizzyFitbit
12-07-2023
19:24
12:53
LizzyFitbit
My new charge 6 is syncing to the app in my iPhone without any problem but when is also trying to connect to Bluetooth? When I go to Bluetooth settings it can’t find the charge 6 but it is syncing?
Anyone else have this problem
cheers
12-07-2023 20:53
12-07-2023 20:53
Hi. @SunsetRunner , the Bluetooth connection with your Charge 6 will always be through the Fitbit app. If you try to find it directly via the Bluetooth settings on your phone it will always fail.
As your Charge 6 is syncing, as you report, then you don’t need to worry at all and there is no problem.
Welcome to the forums!
12-07-2023 21:42
12-07-2023 21:42
