Charge 6 that the screen does not turn on when moving the hand
How can I stop that my fitbit lightens by every movement in the night ? .
2 REPLIES 2
Hello @JouselWelcome to our community forums!
Let me help you with your Charge 6 screen that turns on with every movement.
On your Charge 6 you can set the screen to turn On or Off when you turn your wrist:
  1. Swipe down from the clock screen.
  2. Tap Settings app
  3.  Swipe up to get the full list of settings.
  4. Search Screen Wake.
  5. Select Off.
  6. After turning off this setting the screen doesn't turn on when you move your wrist.
  7. If you want to turn on the app you can tap twice the screen or press the button.
Hello @Jousel
It sounds like you haven't set up a sleep schedule on your Charge 6 yet. When you set up your sleep schedule, your Charge 6 automatically goes into Sleep mode at the start and automatically turns off at the end. Sleep mode will prevent your display from lighting up at night as well as mute notifications. You can double tap the screen to see/wake the screen during Sleep mode, if needed.
This help page (<-- click) has the instructions on how to set up your sleep schedule. Scroll down to the section called "Quiet mode" for the instructions.
Just to share with you, I didn't know about setting up a sleep schedule for several months when I first got my Charge 5. So, like you, my Fitbit kept lighting up when I moved around at night. Setting up the sleep schedule was the answer.
