Charge 6 unable to load goals, and battery draining in hours
Charge 6 is about 18 months old, bought from a friend after Christmas as my Charge 5 had died and she had been given an Apple Watch.
Two weeks ago the battery started draining in hours instead of days, I had been charging it every 5-6 days and suddenly it now needs charging before bedtime and again on waking up. I deleted all deletable apps, use it only as step counter and sleep tracker. It is synching steps and sleep data and my Aria Air scale is synching weight, but under goals it reads “Something went wrong, unable to load goals”.
I have restarted the Fitbit, the scale and my iPhone, phone software is up to date, I’ve deleted and reinstalled the Fitbit app, still the same problems.
1 REPLY 1
While it's great that your Aria Air is sycing to your Fitbit account, that actually has no baring on your issue.  The scale and the tracker are not dependant on each other.  Your issue is with the battery of the device.  Since you have already restarted the iPhone, the device itself, and checked for software updates, the only other options I can think of would be to:
1.) Check the device for firmware updates (these are different than software updates and will usually be shown in the app via a pink banner if one is available to you)
2.) Disable any GPS  capabilities.  You  can find the directions here .
3.) Contact Support for a Battery Test.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
