08-29-2024
08:13
11:42
FatimaFitbit
08-29-2024
08:13
11:42
FatimaFitbit
It worked fine for months. But since this morning there is a big problem! Sleep recording still worked. They were still synchronised. But then it was no longer possible to transfer the recordings. The green synchronisation indicator stopped halfway through. It did not move even after several minutes. So it was cancelled. In the meantime, I went through all the options mentioned in the help section. Several restarts of the mobile phone as well as Charge 6 (with charging cable as well as restart on the screen. Even searching for a mobile phone from Fitbit did not help. No mobile phone found. The mobile phone recognizes Charge 6, but does not connect.
What could be going on? What else can I do?
09-19-2024 11:49 - edited 09-19-2024 11:50
Hi there @bf05! So good to see you in the Community.
Thanks for letting us know about the situation you are having trying to pair your Charge 6 with your phone and for your efforts to try to solve this issue.
Were you able to solve this situation? If not, I suggest you to try this:
