11-24-2023
22:26
12:16
LizzyFitbit
11-24-2023
22:26
12:16
LizzyFitbit
I just bought the charge 6 today and I’m going crazy syncing it to my iPhone. I’ve restarted the phone ,the charge, I’ve I downloaded and redownloaded the app. I’ve disconnected Bluetooth repeatedly. It still won’t fully connect. It shows in my phone but as soon as I go to connect it with the number code it won’t fully connect.
11-24-2023 23:20
11-24-2023 23:20
I’m having exactly same issues with my charge six I got yesterday
11-25-2023 00:34
11-25-2023 00:34
1. I’m having the same problems. Can’t synchronize with iPhone and I’ve done everything I am supposed to correctly many times. Using bluetooth on phone on and even right next to my Fitbit and won’t sync. 2. Also will not give me any data on sleep which is one of the main reasons I bought this Fitbit
11-25-2023 00:37
11-25-2023 00:37
11-25-2023 03:23
11-25-2023 03:23
I have exectly the same problem, just with Android phone. Spent hours by trying... but it just won't connect.
11-25-2023 05:19
11-25-2023 05:19
I'm having exactly the same problem.
11-25-2023 05:22
11-25-2023 05:22
Same problem with my Android phone.
11-25-2023 07:02
11-25-2023 07:02
I am having the same problem! I have reloaded app and turned off phone as suggested, but only mess
age on fitbit is download app! Frustrated. Any solutions?
11-25-2023 13:55
11-25-2023 13:55
I got a mail from the support (... after the support chat collapsed twice before anything could be solved) and it repeated how to install and the it said: "1. Clear the user data using the Charge 6 key sequence "short press - long press - short press".
2. Briefly press the Charge 6 button for a maximum of one second.
3. Press the Charge 6 button for 5 seconds (Hold the button until you receive a confirmation vibration).
4. Briefly press the Charge 6 button again.
5. A dialog appears on the display asking the customer to delete the user data. Ask the customer to tap Accept.
6. Start the Charge 6 setup process again.
And this worked for me, hooray 🙂
11-25-2023 14:02
11-25-2023 14:02
11-25-2023 14:07
11-25-2023 14:07
Keeping my fingers crossed for you to get it solved.
11-25-2023 18:06
11-25-2023 18:06
Hi, can you advise, when you say the charge 6 button, do you mean the button on the USB charging cable or the one on the charge 6 itself? Thanks
11-25-2023 23:57
11-25-2023 23:57
Thank you. All sorted now
11-26-2023 01:00
11-26-2023 01:00
For me it worked with the button on the watch, not tried the charging cable.
