06-09-2024
06:48
06:20
LizzyFitbit
06-09-2024
06:48
06:20
LizzyFitbit
I’ve just got a charge 6 but can’t get a display for my heart rate
Best Answer06-09-2024 14:23
06-09-2024 14:23
Hello @Durnfords
Sorry to see you're having issues with your Charge 6.
Do you see a green light on the back of your device? That's the heart rate sensor. To check, place your finger across the back of the device. You should see the green light when you lift your finger.
If you don't see a green light, check to make sure that Heart Rate is turned on:
If Heart Rate is turned on and you still don't see a green light, try doing a few restarts. This help article explains How to restart a Fitbit (<-- click link)
