01-03-2025 07:54
01-03-2025 07:54
I want to buy a hook & loop band for my new Charge 6. My wrist is between sizes at exactly 6.5". Should I size up to the large since it's the hook & loop or will the small fit without fastening issues?
Best Answer01-03-2025 08:05
01-03-2025 08:05
Hi, @BJeanC! I can't tell you what your preference will be, but I personally wear my band a little loose for comfort. I just measured and my band is almost an inch more around than my wrist.
MakMak | Community Council
01-03-2025 08:37
01-03-2025 08:37
