01-30-2025
07:13
12:46
LizzyFitbit
01-30-2025
07:13
12:46
LizzyFitbit
I am a veterinarian with the Charge 6. To record heart rates I need both of my hands while looking at my wrist. I see that other Fitbits have an option to give you an accurate second hand and will stay on for longer to allow this (I see others call this a nursing clockface). Is there a way to change my clockface, either within the app- none of the clockfaces I see have an readable second hand! - or from a third party?
Best Answer@Startingtostep The clock faces that you see in the Gallery are the only ones available for the Charge 6. There are no third party clock faces for the Charge 6 or any other tracker. Fitbit Fitbit didn't release a software development kit for third party development for apps or clocks faces for trackers.
Do you think you could find a workaround using the timer or stopwatch?
Laurie | Maryland
