11-15-2023 17:57
11-15-2023 17:57
What is the secret to charging the Charge 6? I have had this Charge 6 for about 2 weeks, but every time I go to charge it, I have a problem. I plug it in, it says it's charging, I walk away and then when I come back, I find it hasn't been charging while I've been gone. My Charge right now has been plugged in for 2 hours, but nothing. I keep going over and replugging it in, but it doesn't help. What should I be looking for?
Best Answer12-10-2023 07:27
12-10-2023 07:27
@betpchem I got thirdparty cables from Amazon which seem to stick better (probably use stronger magnets). Still, need to be careful positioning Charge 6 but less likely the cable is going to disconnect. Cables offered by Fitbit have too weak magnets.
11-16-2023 02:54
11-16-2023 02:54
@betpchem that happened to me several times. The charger doesn't seem to stick to the Charge 6 strong enough and slight movement will disconnect it. Really annoying. I usually recharge my Charge 6 when the battery is very low (10% or less) and it's a bummer to take the tracker from the charger and find out it hasn't charged at all.
12-10-2023 07:14
12-10-2023 07:14
One month later, still having the same issue. The cord will not connect to the charge 6. For one brief moment, it might be charging. But then I put it down and it stops charging. It's so annoying!!!!! I might sell this one and go back to one of the old ones. This is awful.
12-10-2023 07:27
12-10-2023 07:36
12-10-2023 07:36
That's a good tip, thank you. I may try that.
Best Answer01-28-2024 15:11
01-28-2024 15:11
My cable seems to work intermittently. If I wriggle the wall plug end, without moving the charge 6, it starts working. I think I need a new cable. It is a pity because it stays on my desk and does not move much.
Thank you @Triletics I found a replacement on AliExpress. I hadn't thought of third party cables.
Best Answer05-05-2024 08:29
05-05-2024 08:29
Why should we be buying another cable when Fitbit should be providing the proper cable?
