06-12-2025 09:02
06-12-2025 09:02
I have a white circle with a dash (or minus sign) in it that appears over the heart rate at top of my charge 6 display. What does it mean? Also, I have seen a + in that same area, and another symbol that resembles a phone or battery (not sure which and it's only there for a moment). Anyone know what all that means? I have the latest iOS app and firmware on the charge 6. I've reset the device. It may have always been there, but I never noticed it before. Thanx!
Best Answer06-12-2025 09:58
06-12-2025 09:58
@MikeyChris Yes, that is one of the Status Indicators released in the recent firmware update. See this Help article with the Charge 6 section expanded. That’s the DND icon. The white phone with a slash means you don’t have a Bluetooth connection. The red battery with a slash means a critically low battery. A circle with a crescent moon is Sleep mode. These indicators were introduced with the Sense/Versa 3. I never recall seeing a + sign on my Versa 3.
Laurie | Maryland
06-12-2025 09:43 - edited 06-12-2025 09:46
Silver Fitbit Product Experts share support knowledge on the forums and advocate for the betterment of Fitbit products and services. Learn more
@MikeyChris I think you're referring to the latest 'status tray', a feature from a recent update to let you know what mode/process your device is in. I currently have an icon that looks like a smart phone and slash across it. I think it means my Charge 6 is not currently paired with my app. I had been trying to locate what icons to expect to try and decipher what I see but I haven't had much luck. A circle with a line through it could suggest Do Not Disturb is enabled.
06-12-2025 09:58
Laurie | Maryland
06-14-2025
08:16
09:49
AndreaFitbit
06-14-2025
08:16
09:49
AndreaFitbit
Thnax for the reply. I'm confused about the BlueTooth indicator because I often get the Phone with a slash throug it but I have a BlueTooth connection with my phone. And the Circle has a dash in the center, not a crescent, so not sure what that is.
Thanx for that link, it explained it all!
