06-25-2025
15:15
18:02
ManuFitbit
06-25-2025
15:15
18:02
ManuFitbit
This seems like it is a source of annoyance for a large amount of people and it has been said before and it will be said again
Please allow the user to disable vibrations and all notifications. It is no longer possible to disable those congratulations and celebrations for making progress towards your weekly goals that you can't even set anymore. So it's very intrusive to have a vibrations come on and not be able to disable them.
There should be a very straightforward way to disable vibrations on the watch itself just like you can toggle between normal and strong vibrations it should also toggle off and then notification wise there should be something under notifications at the top like enable all or disable all notifications because the app does not respect the Android operating systems preferences because Google is deeply integrated with Android and knows all the ways around the permissions. Since they developed those very operating system permissions
Moderator edit: clarified subject.
06-25-2025 17:58
06-25-2025 17:58
Welcome to the community forums @Keelando.
Thank you for sharing with me this inquiry regarding notifications and vibration on your Chare 6.
Unfortunately this is not currently possible. Nevertheless, I'd suggest you vote for this idea in the Product Feedback board of the Community, since this section is regularly monitored by the team of developers. If you prefer to create your own idea, please make sure to post your idea including as many details as possible.
06-25-2025 17:58
06-25-2025 17:58
