04-22-2024 14:24
04-22-2024 14:24
Is there a fix coming for this issue? If not I am going to become a garmin wearer - this is not acceptable from an advanced generation Fitbit which should be progressive not regressive ( I previously had the versa 4)
Best Answer04-22-2024 22:50
04-22-2024 22:50
Hi @Nualalynch ,
Distance is available as the main value on the run screen. Start a run then tap on the main value. You will scroll through the options. Stop tapping when you find the one you require.
Hope this helps!
Best Answer04-23-2024 06:03
04-23-2024 06:03
Thank you - can pace be seen as the same time during a run or do you have to toggle between screens?
Best Answer04-23-2024 07:22
04-23-2024 07:22
@Nualalynch no, only one middle stat can be seen. Before last FW update, the top metric was distance but Fitbit changed it to time of day 🤷
