06-09-2024
06:46
06:30
CrisVillaFitbit
06-09-2024
06:46
06:30
CrisVillaFitbit
English:
I would like to know if FitBit Charge 6 vibrates or beeps when it disconnects from the smartphone due to excessive distance.
Thanks and best regards
In Italiano: Vorrei sapere se FitBit Charge 6 vibra o suona quando si disconnette dallo smartphone a causa della eccessiva distanza.
Moderator edit: edited title to clarity.
06-10-2024 06:38
06-10-2024 06:38
Welcome to the Fitbit Community, @FB-75.
Thanks for letting me know your question if there's a notification when your Charge 6 is disconnected from your smartphone.
Good question! Charge 6 does not have a notification when it is out of range from the Bluetooth of your smartphone. You can check more about the notifications available on your Charge 6 manual.
06-10-2024 16:03
06-10-2024 16:03
My 4 year old Huawei band that cost 30 had that feature .
06-28-2025 17:16
06-28-2025 17:16
Well then I hereby nominate that feature for the charge 6. Can you help make that happen, CrisVillaFitbit?
06-28-2025 18:16 - edited 06-28-2025 18:19
Hi @BarryMart Fitbit added this feature in a recent firmware update. If your Charge 6 is very new, then you might not have received it yet. It might take 24-48 hours if your device is new.
Fitbit calls these Statuses Indicators and there are four. They are on by default.
Laurie | Maryland
06-28-2025 21:11
06-28-2025 21:11
06-30-2025 06:36
06-30-2025 06:36
@BarryMart Fitbit released these Status Indicators with firmware version 214.24.
Laurie | Maryland
