03-30-2024 00:20
03-30-2024 00:20
Hello, i just purchased the charge 6 and thought the total calories burned yesterday looked a little high, for context I am 22M, 271ibs, just started working on my fitness so im not sure if that number is typical for what i did.
Steps: 12,239
Zone minutes: 50
Miles: 5.68
Calories: 4,361
Best Answer03-30-2024 13:54
03-30-2024 13:54
Hello & welcome @ZacharyB717
That does seem like a higher number of calories for the tracked distance.
Just brainstorming here: Have you confirmed that your birth year is correct for your Google account? Several users discovered that their Google account has their birth year as "1900".
To check your information:
Best Answer03-30-2024 19:27
03-30-2024 19:27
Thank you for the response, my Birth year is set accurately, i read that the fitbit tracks passive calorie loss as well, if thats true the total numher i burned activity is only around 3000
I also forgot to mention in the original post that i did a 30 minute cardio session where it tracked about 500 calories lost in that time
Best Answer03-31-2024 14:43
03-31-2024 14:43
Hi @ZacharyB717
Thanks for confirming your birth date is correct.
I did a search and found this help article which includes an explanation on how Fitbit calculates calories burned (<-- click link).
You might want to monitor your daily calorie burn and see if you continue to get similar numbers. You could actually be getting that level of calorie burn with your activities.
