11-18-2023
10:57
11:56
RodrigoMFitbit
11-18-2023
10:57
11:56
RodrigoMFitbit
I only do one type of exercise. Can i eliminate the scrolling and have only this exercise type appear first.
Hello @Elliptical_only
The first time or so, you'll have to scroll down to get to your preferred exercise. After that, your preferred exercise will show at the top of the list and you won't need to scroll down to get to it.
@RiekoC Thanks for your help. Top!
@Elliptical_only Welcome to the forums. Thanks for your posts about the exercise shortcuts on your Fitbit Charge 6.
Please note that the list of trainnigs will be sorted automatically based on your most selected trainings. As explained above, the more you use an activity, it will be shown at the top of the list. However, there is no way to do this manually. It is just a matter of time. I appreciate your understanding. Wishing you the best when training with your Fitbit Charge 6!
Best AnswerI went to my dashboard on fitbit.com and when I went to the section about my device, I could eliminate the shortcuts I didn’t want and add a couple that had disappeared from my fitbit. You can change the order as well.
You need to sync the app (the shortcuts there don’t change) and reboot your device.
Not even on the website? I don’t have the option on my device (Luxe) but it is on my Dashboard at fitbit.com. Then I had to sync through the app (it still didn’t show there) and changed on my device after I rebooted it.
Best Answer@Debbilu7 nope - that option doesn't appear on the web or in the app for the Charge 6. You couldn't change the order on-device with the Charge 5 either, but you could do it in-app and on the web.
@RodrigoMFitbit is there anything you can share with us about how that MRU (most recently used) list works? I think at one time, I saw 3 of the ones I used most, but now I only see one. Does it drop ones you don't use as much? How long do they stay in the list?
Best AnswerHi. I have a Charge 6 and that option is not available to me on Fitbit.com. Do you have a Charge 6?
Hello everyone. Thanks for reaching out about the exercise app on the Charge 6.
The exercises shown at the top are the ones that have been used recently. I am currently wearing another Fitbit device but it should work similarly. The ones I start regularly on my device are shown at the top. However, after some time they will re arrange. I honestly have not determined after how much time a training is dropped from the "most recent" list. The exercises that are most used do show up at the top. Regarding the settings on the website, that was for older models where you could re arrange and personalize the list. However, now that all exercises are shown on the device, they are sorted automatically and by frequency. Thanks for your understanding.
You can suggest to bring that functionality back though. The best place to make your voice heard is the "Product Feedback" board, where you can submit your ideas and share it with other members. The suggestions with more votes are taken into consideration by our developers for new updates or product development.
