11-10-2025
15:17
15:29
StefanieFitbit
11-10-2025
15:17
15:29
StefanieFitbit
Thank you for your patience as you waited for the firmware update.
This update includes key fixes for battery and display issues, along with new clock faces for Charge 6.
Please keep an eye on the Fitbit mobile app for the update notification as it continues to become available to all users, beginning this week.
Thank you for your continued support and patience!
01-27-2026 18:45
01-27-2026 18:45
Acting very odd since update. Wasn't syncing until I restarted the watch. Battery was 37% before I restarted, 18% after. It did sync, but shows no sleep number or graph for last night, just 6h 37m.
Best Answer9 hours ago
9 hours ago
Hello @tcat007
Following up with you.
Did your sleep graph & data finally show up? I was also having issues with syncing and sleep data on the same day. My sleep graph finally showed up later in the day when I was able to sync.
Best Answer5 hours ago
5 hours ago
Since receiving the update notification my fitbit charge 6 screen keeps glitches out. I just updated it to see if it fixed the issue but it hasnt. Also battery went from 89 to 12% withing 30 minutes. It typically goes a week or longer on a full battery let alone 89%. My issue is my screen goes white to a yellow/green and some times looks like an old cable TV when the antenna stops receiving.
Best Answer4 hours ago
4 hours ago
Try rebooting with button on the charging cable. Mine is still giving me 9 days between charges.
