05-27-2024 05:39
05-27-2024 05:39
Hello,
is there any documentation available for communicating over BLE with the HR Equipment feature of the Charge 6?
We have an fitness app for the gym that we would like to integrate the fitbit charge 6 with.
Any help (especially pairing) would be appreciated.
Best Answer05-27-2024 20:25
05-27-2024 20:25
Hi @Pablo0515 - the only way to communicate with the Charge 6 is via the Fitbit App.
There is no SDK for this watch so your post is moved to the watch forum.
Best Answer05-27-2024 22:39
05-27-2024 22:39
@Pablo0515 you need to use BLE HR profile: https://www.bluetooth.com/specifications/specs/heart-rate-profile-1-0/
It's pretty standard and easy to use on Android (not sure about iOS). Charge 6 should work but may require more complex handshake process (hence it's often not working with software that doesn't use encryption which is most of the software).
06-01-2024 00:18
06-01-2024 00:18
Thank you for the reply. I have seen the heart rate profile. But i could not manage the handshake, nor find info about the implementation.
Does fitbit share this handshake info somewhere? I’d like to be able to receive the heart rate data in our monitor app.
