07-09-2025 08:44
07-09-2025 08:44
I use a rollator when I'm out and about, and often my fitbit will start randomly tracking biking. I always dismiss the alerts, but then they appear in my workout history as "mountain biking" and no matter how many times I go in to correct that I'm simply walking, the edits won't stick. has anyone dealt with something similar and found workarounds?
Best Answer07-10-2025 07:55
07-10-2025 07:55
It's been known to happen since Fitbit interprets the motion and tries to fit it with the best auto detect exercise. When I'm pushing a shopping cart it thinks I'm on a mountain bike. I do try and correct the exercise and sometimes it lets me save, sometimes not. This unable to edit workouts is a known issue, unfortunately. I believe you can disable the auto-detect exercise in either the app settings or the device settings. But then you might have an issue trying to manually log the workout later, say add a walk, as sometimes, manually additions don't save (also a known issue).
