01-09-2024 08:11
01-09-2024 08:11
How is it possible that an exercice started on the fitbit Watch and later synchronised onto Strava differ in terms of distance, time of exercise and pace ? When synchronising to Strava, the exercice is always shorter in terms of distance and time than indicated on the “run option” on the watch
01-09-2024 10:49 - edited 01-09-2024 10:51
I am not syncing Fitbit with Strava, but something similar is happening to me as well when I am syncing my runs from Polar Flow to Strava. Like the average heart beat would be different or average pace. It might be that Strava is applying its own calculations when transfering data over. Just a guess. Like today, on Polar Flow the pace was 9:12 min/km, on Strava 9:10 min/km, HR avg 128 bpm compared to 129 bpm on Strava. Not much of a difference but still. It shows that Strava does not simply copy the data over.
01-09-2024 16:01 - edited 01-09-2024 16:03
@ninaoostv24 when you upload to Strava, the GPS distance is calculated and you see "moving time" as a duration (Fitbit shows elapsed time). Pace is recalculated based on moving time and GPS distance. Charge 6 doesn't use GPS to estimate distance during run hence differences (actual map distance is always different than distance reported by Fitbit). Strava integration is quite poor.
@SunsetRunner that is correct that Strava recalculates the data however there is a way to prevent it and force Strava to get data "as-is" which is done so by Garmin or Suunto.
