Fitbit charge 6 alarm switches to AM when I press PM and vice-versa Make a paragraph for this on fit
Hi everyone,  I've noticed an issue with my Fitbit Charge 6 alarm. Sometimes when I try to set it to PM, it switches back to AM, and vice versa. It works correctly sometimes, but not always, which makes setting the right alarm tricky. Has anyone else experienced this? Any answers would be appreciated!
1 REPLY 1
Hi @Sp3ncer - It seems to be working fine for me, but, for what it is worth, even if you’ve lined up the desired setting (am or pm) so that it is illuminated at the middle of the screen on your CH6, it is still possible to select the other (greyed out ) setting if you tap directly on it at the bottom of the screen. So, make sure you are tapping in the middle of the screen when making your choice.
Scott | Baltimore MD
