Fitbit lost my goals; reset didn’t work
ANSWERED
I suddenly am unable to find my sleep goal comparisons, the app says “there was a problem” when I went to goal settings.  I tried  resetting, still no luck. Can someone please help?
1 BEST ANSWER
Accepted Solutions
I did exactly what to recommended:
Logged out of the app on my iPhone;
Deleted the app from the phone;
Turned my phone off and then back on after a short wait;
Installed the app on the iPhone again and logged in.
Goals now appear.
8 REPLIES 8
@Timefit , A warm welcome to the Community! Thank you for your message and information.
Our team is aware of this and are looking into it. They will work on a solution afterwards.
In the meantime, we have noticed that turning your phone off and on again has helped other users.
A try is worth it.
Any update on this? I’m having the same issue on Charge 6. Goals have disappeared and the link to goals doesn’t work either.
Hello @juliejo1014
Have you had a chance to restart your phone to see if that will restore your goals?
What version of the Fitbit app do you have? The most current version is 4.42.2. To find your version info:
  • Tap on your picture/avatar in the upper right of the Today page in the Fitbit app
  • Select Help in the menu that opens
  • Your Fitbit app version info should be on the page that opens
@RiekoC Thank you for your message and help.
@juliejo1014 , A warm welcome to the Community! Thank you for your message and information.
Adding to the info provided by our friend RiekoC , did you tried restarting (off/on) your phone?
If any of these steps have helped, try the following:
 Sync your Charge 6 with the Fitbit app.
Log out of the Fitbit app.
Uninstall the app.
Restart your phone ( off /on)
Reinstall the app  and log in.
Thanks much. That worked!!
@juliejo1014 , Thank you for your reply and confirmation.
I'm glad to read that the info was helpful.
Could you please describe what steps helped you so that other users can try them, should they encounter the same issue?
Goals now appear.
@juliejo1014 Thank you for confirming the steps.
I'll mark you reply as the Best Answer so that other users find it easier should they encounter the same issue.
Please visit our discussion forums. There you'll find several users interested in fitness, healthy eating, or better sleep, who share many tips. They'll be happy to meet you there.
