05-13-2025 11:47
05-13-2025 11:47
I suddenly am unable to find my sleep goal comparisons, the app says “there was a problem” when I went to goal settings. I tried resetting, still no luck. Can someone please help?
Best Answer05-19-2025 19:17
05-19-2025 19:17
I did exactly what to recommended:
Logged out of the app on my iPhone;
Deleted the app from the phone;
Turned my phone off and then back on after a short wait;
Installed the app on the iPhone again and logged in.
Goals now appear.
05-14-2025 16:49
05-14-2025 16:49
@Timefit , A warm welcome to the Community! Thank you for your message and information.
Our team is aware of this and are looking into it. They will work on a solution afterwards.
In the meantime, we have noticed that turning your phone off and on again has helped other users.
A try is worth it.
05-18-2025 06:06
05-18-2025 06:06
Any update on this? I’m having the same issue on Charge 6. Goals have disappeared and the link to goals doesn’t work either.
05-18-2025 10:01
05-18-2025 10:01
Hello @juliejo1014
Have you had a chance to restart your phone to see if that will restore your goals?
What version of the Fitbit app do you have? The most current version is 4.42.2. To find your version info:
05-18-2025 15:55
05-18-2025 15:55
@RiekoC Thank you for your message and help.
@juliejo1014 , A warm welcome to the Community! Thank you for your message and information.
Adding to the info provided by our friend RiekoC , did you tried restarting (off/on) your phone?
If any of these steps have helped, try the following:
Sync your Charge 6 with the Fitbit app.
Log out of the Fitbit app.
Uninstall the app.
Restart your phone ( off /on)
Reinstall the app and log in.
05-19-2025 07:22
05-19-2025 07:22
Thanks much. That worked!!
05-19-2025 10:11
05-19-2025 10:11
@juliejo1014 , Thank you for your reply and confirmation.
I'm glad to read that the info was helpful.
Could you please describe what steps helped you so that other users can try them, should they encounter the same issue?
05-19-2025 19:17
Goals now appear.
05-20-2025 10:28
05-20-2025 10:28
@juliejo1014 Thank you for confirming the steps.
I'll mark you reply as the Best Answer so that other users find it easier should they encounter the same issue.
Please visit our discussion forums. There you'll find several users interested in fitness, healthy eating, or better sleep, who share many tips. They'll be happy to meet you there.
Best Answer07-21-2025 09:05
07-21-2025 09:05
I have tried everything- I lost my goals, some data charts no longer appear. I’ve updated the app, I’ve started and restarted my phone, I’ve logged out of Fitbit and back in - all to no avail. I have tried to uninstall the app and have em is new problem- I’m only given the option to remove the app from the Home Screen. It stays in my Library. The “uninstall option” doesn’t show at all. What can I do?
