08-09-2025 01:37
08-09-2025 01:37
From 5 Aug fitbit does not provide any data on sleep heart readings etc
Best Answer08-09-2025 04:43
08-09-2025 04:43
Hello @Hijack61 !
Please review the Topics in the appropriate Fitbit Application Forum. I surmise you are using an Android device, as recently this issue occurred for myself and many Android device users. It think it has been resolved, although there may be a "catching-up period" for all your data to again appear as expected.
Best Answer08-09-2025 10:19
08-09-2025 10:19
Hello @Hijack61
Do you see a green light on the back of your Charge 6? That's the optical heart rate sensor. In addition to tracking your heart rate, it is also used for sleep tracking.
If you don't see the green light, check the Settings tile on your Charge 6 and confirm that Heart rate is turned on:
Best Answer08-09-2025 16:44
08-09-2025 16:44
Best Answer08-11-2025 10:27
