03-18-2025
18:30
- last edited
11 hours ago
LizzyFitbit
03-18-2025
18:30
- last edited
11 hours ago
LizzyFitbit
The step counts seem to be okay, but it's showing that my step count goal is 0. I can't find anyplace to change to my correct step count goal. Is this due to yesterday's updated app?
yesterday
yesterday
Targets for floors, active minutes, distance, calories burned and steps do not appear in app.
For example if I did 20000 steps yesterday, it says I exceeded my goal by 20000 steps, because it believes my step goal is 0, when in fact it's always been 10000.
Under "You" , goals, see all - I can only see exercise days and hourly activity as available goals.
I have updated phone, app, restarted, logged out, restarted device.. nothings working
If I log out and log back in, the goals reappear for about a minute, then disappear again.
I have no apps synced, health connect is disconnected.
yesterday
yesterday
Hi there, @jerseystar.
I'm glad your step count is showing correctly and to change your daily goal, please give a try to the following:
By the way, I've moved your post to the Android board. This is because your question relates to a different issue, and this will help us to prevent any confusion for other members.
yesterday
yesterday
Thank you for responding. However, I have done exactly what you said and the Goals list does not include number of steps or total distance. All that is listed is Sleep (bedtime, wake time, sleep duration); Activity (exercise days, hourly activity); Health; Weight; Body fat percentage; Mindfulness; Mindful days; Nutrition; Food; Water. When I go to Today, the dot on the circle around the step icon starts to move, as if the goal is 8000 steps (what I had originally set) and then it slides right back to the start because it says my goal is 0 steps. This has only been occurring for the past few days -- I assume since the latest app update.
yesterday
yesterday
I have the same issue and that also doesn't work as the step goal does not come up
yesterday
yesterday
Seeing exactly the same no way to edit target step count.
Graphics for Steps, miles and cal all sweep round then go back to zero though actual data still show in numbers.
Android app ver 4.39
yesterday
yesterday
Hello @jerseystar
Which version of the Fitbit app do you have? I'm on version 4.38 and see categories under Activity that you apparently aren't seeing:
Hello @Antoeknee
Are you seeing the same list as @jerseystar under Activity when you tap on the You tab and tap on Goals > See all?
yesterday
yesterday
As per my post ver 4.39.
My wife still has 4.38 and sees the same as you.
yesterday
yesterday
Sorry should have said I see the reduced list as @jerseystar
yesterday - last edited yesterday
Hello @Sanso14
I've seen a few other users reporting the same. I'm currently on version 4.38 and am able to see the full list of goals under Activity.
Please report this issue using the Feedback option in the Fitbit app:
Although it's likely that you won't receive a response, the team receives & reviews the feedback reports.
I'll be watching for your reply about what app version you're on. If you started seeing this issue after updating to version 4.39, I will try to escalate this to the team.
yesterday
yesterday
Hello @Antoeknee
Thanks for confirming you've got app version 4.39 & that your wife on app version 4.38 sees the full list of goals.
I saw another user report the same issue (<-- click link) & asked them which app version they have.
yesterday
yesterday
My Fitbit app isn't letting me set a step count daily goal or distance goal. Anyone else had any similar issues?
yesterday
yesterday
Hi @RiekoC I have the same issue (all goals gone), and have 4.39 (110248068)
My Android phone had an update installed today and since then my step goal, active minutes and calories burned goals have all reset. Step goal is now zero, down from 11k, active minutes at 22 instead of 30 and the app only lists two activity goals to set.
App version is 4.39
I've rebooted the phone and Fitbit twice to try and restore step goals but have been unsuccessful. Has anyone else had this problem?
yesterday
yesterday
@RiekoC Confirmed it's related to 4.39, I removed it and installed 4.38 and the goals are back.
yesterday
yesterday
Hi! I also have the same issue, all activity goals are gone except Exercise days and Hourly activity. Weirdly enough, when I look at "Activity" under "Goals" in the "You" tab I can sometimes see how the number starts at 6, but then plummets down in under maybe a second to 2.
It seems to be related to the app version. I recently got a new phone. On my new phone I have version 4.39 (110248068) and this is where the issue comes up. On my old phone the app hasn't updated yet and is at 4.38 (110235289) and there is no issue there. I can also add that on the old phone the number of activity goals is set at 6, the same number I could see the activity goals plummet down from like I described above. Maybe that means something.
yesterday
yesterday
I suddenly noticed that on my app I no longer have goal steps and goal distance to walk.
This morning I have 42 of 0 steps... instead of 42 of 8000. I go to my Actvity Settings where I can change my hourly activity or exersise days, I thought I could change my step goal there.
Did that setting move somewhere? Did daily step goal get set to 0 for others as well?
19 hours ago
19 hours ago
Hello @Pol3202 and welcome to the Community. Do you use an Android phone? It looks like there is a bug in an app udate. Other Android users are posting about this, too.
Laurie | Maryland
19 hours ago
19 hours ago
Hi,
Yes I do use an Android phone. I have reported this issue to the support team this morning. Waiting to hear back from them.
17 hours ago
17 hours ago
Yes, same thing is happening with me!
