11-10-2025
08:51
12:37
HorareyFitbit
11-10-2025
08:51
12:37
HorareyFitbit
Hi ,
I seem to be having this issue ever since I updated the fitbit charge 6. Now it keeps asking me to sync from the fitbit mobile app and the fitbit mobile app keeps tryiong to update the fitbit buit keeps failing. As a result, my charge 6 is not able to be used at all and the fitbit app says could not update. I am at a loss as to what to do with it now. Can anyone advise ?
Best Answer11-10-2025 13:03
11-10-2025 13:03
Hi @WeeCH1 Welcome to the Fitbit Community! It's great to have you here!
I see what you're going through with syncing your Charge 6, I'm more than happy to assist you today.
I can suggest you the following article to help you with your situation, "Why won't my Fitbit device sync?"
If needed this article can help you upload your device. "How do I update my Fitbit device?"
11-10-2025 13:42
11-10-2025 13:42
Hello @WeeCH1
Have you tried uninstalling the Fitbit app from your mobile device, re-installing the app, then adding your Charge 6 as a new device?
Give this a try and let us know if it worked for you.
02:14
14:28
ManuFitbit
11-11-2025
02:14
14:28
ManuFitbit
Hi,
Have read the followinf and tried the steps but to no avail. the watch keeps showing "sync from the fitbit mobile app" and there is no way to access into the watch at all
Have tried the steps you mentioned as well but again, the watch just shows the following "sync from the fitbit mobile app" and the fitbit app keeps saying could not update and keeps asking to try again
Best Answer11-13-2025 13:34
11-13-2025 13:34
Hello @WeeCH1
The other troubleshooting step that I've seen is access the Fitbit app on your phone and do a Force stop. Then, open it and see if you can sync.
