On my home screen where the clock is, it has the heart icon followed by 2 dashes....How do I get it to display my heart rate? Every so often it does but usually just 2 dashes. This thing is NOT very user friendly
Hi @KerryH67 Welcome to the Fitbit Community! It's great to have you here!
Let me help you with the heart rate reading of your Charge 6.
If you see some dashes instead your actual heart rate, it's possible that your device is not receiving a strong signal. I recommend that you take a look at our help article What factors can affect my heart-rate reading on my Fitbit device?
I hope these suggestions will be helpful for you.
Best AnswerHello @KerryH67
Do you see a green light on the back of your Charge 6? That's the heart rate sensor. You can check by placing your finger across the back of the device. You should see the green light when you lift your finger.
If you don't see the light, the first thing to check is that Heart rate is enabled in the Charge 6's Settings menu:
Please let us know if you are seeing your green light sensor.
