08-11-2024
07:54
08:44
LizzyFitbit
08-11-2024
07:54
08:44
LizzyFitbit
My Charge 6 is tracking my heart rate etc. I can see the data in the app. However the values are not showing on the watch. The red heart symbol is showing but no value next to it. I haven’t changed any of the settings.
Best Answer08-11-2024 10:35 - edited 08-11-2024 10:36
Hello @Bluedave402
Sorry to see you're having issues with seeing your heart rate on your Charge 6.
Since you're still seeing heart rate data in the app, I take it that you see the green light on the back of your Charge 6. That's the heart rate sensor. To check, put your finger across the back of your device. You should see the green light when you lift your finger.
You might want to try these steps to get your device to show your heart rate:
08-11-2024 10:38
08-11-2024 10:38
Hi @RiekoC,
Thanks for your quick reply. I’ve just restarted it and it’s sorted out the problem. I appreciate your help.
Dave
08-11-2024 10:43
08-11-2024 10:43
Hi @Bluedave402
Thanks for letting us know that a restart fixed your heart rate issue. Glad that it was a quick and easy fix. 👍
Best Answer08-12-2024 03:09
08-12-2024 03:09
After years of being a Fitbit loyalist the charge 6 is garbage my heart rate won’t go above 87 no matter what. 90 mins of cardio and I got 12 zone mins charge 5 that was 170
