03-13-2025 08:00
03-13-2025 08:00
How can I change the name of an existing workout to: Drum Exercises or start a new workout with the name: Drum Exercises.
I have a Fitbit Charge 6. Thanks in advance for an answer.
Best Answer03-13-2025 14:17
03-13-2025 14:17
Hello @Phonzy
Currently, there's been an on-going bug that affects our ability to edit the name of completed workouts. The team is aware of the issue and has been working on fixing the problem.
At this point, there isn't any troubleshooting that we can recommend since the issue is on the Fitbit side.
There isn't a way to start a workout session with a customized name. It's suggested to use Workout to track activities that aren't included in the Fitbit's Exercise list.
03-14-2025 15:32
03-14-2025 15:32
I accidentally clicked on yoga as my activity. Now it is stuck on yoga and can’t get out of it. How do you change the activity.
Best Answer03-15-2025 13:56
03-15-2025 13:56
Hello @Wollemipine
Were you able to stop the workout session on your Charge 6? You would need to stop the session first. After you do that, you can then scroll through the list of available activity types and select the one that you want to use.
Just to let you know, the Charge 6 has a feature where your most recent activities will be listed at the very top so you can easily select it. I don't remember how many activities will appear in the Quick pick list, but I think it's at least 3.
Best Answer03-17-2025 07:28
03-17-2025 07:28
Thanks for the feedback.
I was able to stop the workout session on my Charge 6. After stopping the session on my Charge 6, clicking Edit Workout in the Fitbit app, I am unable to scroll through the list of available activity types.
I don’t see the most recent activities feature in the app.
Best Answer03-17-2025 07:28 - edited 03-17-2025 07:31
Sorry, I can't help you with this.
Best Answer03-17-2025 07:32
03-17-2025 07:32
