12-20-2023
18:15
04:23
CrisVillaFitbit
12-20-2023
18:15
04:23
CrisVillaFitbit
How do I turn off the annoying stop exercise/ continue exercise question? I frequently push the stop as it's on top which ends my session.
Moderator edit: edited title to clarity
12-21-2023 09:44
12-21-2023 09:44
Best Answer12-21-2023 04:26
12-21-2023 04:26
Hi, @Rikkitikitave Welcome to the community.
Thanks for letting me know about this situation with the exercise app on your Charge 6. I was able to confirm you need to update the firmware version of your device, this may impact the use of your Fitbit device, you can find more information here on how to do so.
Also, I recommend you doing a restart before starting a workout using the exercise app once again.
12-21-2023 09:44
12-21-2023 09:44
Best Answer01-22-2025 05:06
01-22-2025 05:06
Same problem here. Something forced that no one asked for. Given it was part of an update and there is no update required, firmware or is, what is the correct answer Fitbit/Google?
