10-19-2023 14:46
10-19-2023 14:46
How many exercise's will it hold at once that you can scroll through?
Best Answer10-20-2023 05:05
10-20-2023 05:05
@coolkid83 The Charge 6 put all the shortcuts on the device itself. Say good bye to choosing and customizing your exercise shortcuts. A friend showed me their Charge 6. I can't confirm the exact arrangement on the Charge 6. I use a Sense 2, which also has all the shortcuts on the device. On the Sense 2, you see the most commonly used shortcuts first, followed by the others. As you use shortcuts, your list shows your recently used shortcuts at the top, followed by the others.
Laurie | Maryland
10-20-2023 05:05
10-20-2023 05:05
Laurie | Maryland
10-20-2023 08:26
10-20-2023 08:26
It has 4 recently used on top (without duplicating, if you run twice in a row, only one Run is on top) and the remaining 36 after selecting "More" at the bottom of the screen.
