How to check Charge 6 heart rate during exercise?
 Hi all,
can anyone advise how to check for my exercise screen? In the past I can see via my heart selection button. But not anymore.
5 REPLIES 5
Hello & welcome @Zeitgeist88
If you are asking about seeing more details about a specific exercise that you did, you should be able to tap on the completed exercise. That should open to another page with the details.
If this isn't what you're looking for, please let us know and we will do our best to help you.
Thanks. But I still am unable to go to that screen.
Get Outlook for iOS<>
Welcome to the community, @Zeitgeist88@RiekoC Thanks for your help.
@Zeitgeist88 Thanks for the screenshot and details provided. Just to confirm, does the exercise screen look the same as the screenshot you provided? I'm asking this as we recently had a new update which brought changes to the Fitbit app. This also applies to the exercise tile which displays your details and graphs in a different format. To learn more about these changes, let me recommend checking our blog.
If by any chance you're referring to something different, please provide us with more details or screenshots so I can look into this.
Hi lizzy,
In the past I used to be able to access my heat rate data from
Now I can only see.
Due to the app upgrade version. Or maybe there’s another way to access that I don’t know?
Hi there, @Zeitgeist88.
Thanks for getting back and for the additional details. As you noticed, the Fitbit app has been updated and certain options can be found in a different place, or with a different format. However, all your information will continue being available as long as your Charge 6 keeps syncing.
That being said, after completing an exercise, just tap on the Exercise tile and then on the log to see all your information including your heart rate readings (see screenshot below):
