08-21-2024
09:47
05:13
CrisVillaFitbit
08-21-2024
09:47
05:13
CrisVillaFitbit
My Charge 6 gets a notification every day that I reach 10k steps, and then another one if I reach 20k steps and so on. I want to disable this but I can't find how.
"Step goal progress" and "Exercise goal progress" notifications, as well as "Reminders to Move" are already turned off so please don't suggest those.
Moderator edit: edited title to clarity.
08-22-2024 02:44
08-22-2024 02:44
Hi, @Dricara , I would suggest you try setting a step goal so high that you won’t achieve it.
To change your step goal from the opening screen of the app click on the small gear icon top right. On the next screen scroll to find Activity (under Preferences). Then choose steps. Use the + to increase your goal by 500 steps with each tap. When your goal is high enough that you know you won’t achieve it, choose “set goal” and then sync your Fitbit. I think this should work as I think the extra celebrations for every 10k steps only kicks in after you have achieved your goal, but I am not absolutely certain…. If you test this and it works please post again here to confirm!
08-22-2024 05:17
08-22-2024 05:17
Welcome to the community, @Dricara.
Thanks for letting me know about this situation in regards to the goals notification on your Charge 6.
I truly appreciate your insight, @Julia_G. @Dricara you can set up a high goal as @Julia_G mentioned. You can check this article for more information on how to set goals and main goals.
