01-06-2024
05:19
20:44
EstuardoFitbit
01-06-2024
05:19
20:44
EstuardoFitbit
I want to run X minutes and then walk Y minutes, and repeat Z times. How do I set my Charge 6 to notify me at the end of each interval, and when I am done? I could do this with my Charge 2.
Best Answer01-06-2024 06:05
01-06-2024 06:05
I can answer myself.
On the Charge 6, go to "Exercises" and select "interval Workout". Swipe up to "Set Inervals". From there it is pretty easy.
01-06-2024 06:05
01-06-2024 06:05
01-06-2024 06:06
01-06-2024 06:06
Only took me two hours to figure out!
01-06-2024 06:31
01-06-2024 06:31
The HIIT setting will allow you to do these intervals, set the time for move/rest (run/walk in your case) and the number of times you repeat it.
For example, I have a 15 minute routine which is based on 30 seconds move and 30 seconds rest repeated 15 times.
05-28-2024 14:54
05-28-2024 14:54
Pretty easy....yeah, right.
Best Answer01-04-2026 14:29
01-04-2026 14:29
Somehow mine is set but I don't want to use it. How do I remove/disable interval setting?
the exercise shortcut has only 7 and doesn't let me add or make any edits. now it stops at 9 min for some reason and unable to make that longer either.
Help!
