07-09-2024
16:23
18:28
ManuFitbit
07-09-2024
16:23
18:28
ManuFitbit
Moderator edit: clarified subject.
Best Answer07-09-2024 18:27
07-09-2024 18:27
It's good to see you participating in the community for the first time @Sreptooth.
Thank you for taking the time to share the inquiry regarding your Charge 6.
I'd suggest you wearing your Fitbit on your non dominant hand, but in the settings on the app, set it to dominant. Setting it to dominant will cause the program to be a little less sensitive to hand movements. You can find more useful information about the accuracy of Fitbit devices and how to adjust your stride length and dominant hand settings here.
If you are about to do something that you know involves a lot of hand movements (in your case driving a forklift) it may be helpful temporarily to slip the Fitbit in your pocket.
In addition please confirm if you are using Mobile track. It is a service that allows you to count steps using your phone even if you forget to wear your Fitbit. You can "unpair" Mobile Track from your account. On your Fitbit app go to the upper left corner, on the phone and device icon. Click on your phone icon and on the 3 dots and choose "unpair".
07-15-2025 03:38
07-15-2025 03:38
I just got this charge six and I’m having a similar problem but it’s a bit absurd because even before I got out of bed and when I reached for things in bed, it counted steps now I’m sitting here and my computer in the morning using my left hand or right hand to drink, coffee and every time I move it it’s counting a step How do I just turn it off because if I leave it on on the handheld I think it’s going to be completely useless. Unless you have another suggestion by the way this was the one number one reason I bought it
