06-07-2024 08:02
06-07-2024 08:02
Several times a day I have to sync my phone to my Fitbit as it does not do automatically. Does anyone know how to fix this? I feel like I tried everything. I’ve updated my phone, my Fitbit app, restarted the phone, restarted the Fitbit, disconnected the Fitbit and then reconnected it, and disconnected the Bluetooth and reconnected it. Is there anything else to try?
06-07-2024 08:13
06-07-2024 08:13
Wish I had an answer I’m having the same problem!!
06-07-2024 09:04
06-07-2024 09:04
Make sure you can still charge it. Mine got to 20% last night, so I put it on the charger and couldn't get a response (no clock, no charging level, nothing.) App said I had 16% charge, but that it had last tried to sync 15 minutes earlier. The time it said it last synced kept increasing, but I could not get it to charge, sync, anything. Fitbit is sending a new one, but this is the fourth watch since I bought a Charge 5 in May 2022. I think they've got some kind of serious problem.
Best Answer06-07-2024 09:55
06-07-2024 09:55
I had a similar problem until I turned off the power saving mode on my phone. after that no resyncing required and gps remained during my walks
06-07-2024 11:57
06-07-2024 11:57
Best Answer09-25-2024 11:23
09-25-2024 11:23
I'm having the same problem. It started happening after a phone update. I'm about to switch to a Galaxy watch too many issues with fitbit
Best Answer07-27-2025 19:24
07-27-2025 19:24
I have the same problem with my watch. I have to sync it several times a day. So annoying. I thought it was a problem with the clock face tried changing it and the same thing.
