12-14-2024 10:38
12-14-2024 10:38
I have been using my Fitbit Charge 6 for three weeks and I am impressed. However, I suspect that there is a heart rate floor built in the watch since when I reach this pulse in the night, it become almost like a floor. It could be for like 40 minutes. More realistic would be if it is going from 37 to 38 I guess? Also, I suspect that if it does have a floor of 38, the REM-sleep calculation will not be correct. Something which I have very little of according to the watch...
Does anyone know if the Charge 6 have a heart rate floor of 38?
Best Answer12-14-2024 23:11
12-14-2024 23:11
Now I have simulated a pulse below 38 and found that Charge 6 is not able to register it. When pushing below 38, the watch starts to jump all over the place. (I used the homepage https://www.trickmywatch.com/, and tweaked the javascript so that it is possible to set a value below 60 (update: function () { app.freq = 35;). You also have to set it to Charge and increase steps to max).
12-14-2024 23:11
Best Answer12-15-2024 04:05
12-15-2024 04:05
Hello @warpi and welcome to the Community. I found an article in the Fitbit Enterprise Blog that lists 30 bpm as a floor for Fitbit's OHRM. Different Fitbit models can have slightly different OHRMs, but I believe that 30 bpm is required across models. Fitbit used to list 30 bpm in their Help article. I don't have personal experience with a Charge 6. But I have recorded 36 bpm with my Sense 2.
Laurie | Maryland
08-23-2025 02:35
08-23-2025 02:35
Hi @warpi , slightly late to this thread but I have noticed the same thing. My previous Charge 5 showed a variable minimum range of 33 - 38, my Charge 6 always shows a minimum of 38, so I assume there is a floor of 38 bpm. I assume there is no way to change it. Slightly annoying as this could affect resting and sleeping heart rate values. I might even try and get another Charge 5…
