Is there a good readable Fitbit Charge 6 clock face?
I am looking for a clock that is very easy to read. Other than that it should be possible to display the battery percentage.
Comments about the existing faces:
  • Fast Lane: Is hard to read because there is litte gaps inside the numbers. (Fitbit actually advertises it as "easy-to-read")
  • Sans: Is hard to read, because the minutes overlap the hours. - This would be my choice if it would not had the overlap...
  • Big & Bold: Is easy to read, but I don't need to seconds indication, which is actually more confusing than helping. Also it is missing the battery percentage next to the time.
  • all the others have far too much stuff
3 REPLIES 3
@voomdoon Welcome to the forums. Thanks for your feedback regarding the clock faces available.
I would select one of the following:
  • Continuum
  • Vogue
  • Retro
  • Ripple
  • Progressive
In order to check the battery level, swipe up. At the top of your daily stats you will see the battery level.
I understand some may not appeal to you, but that is the reason there are several options. I appreciate your feedback. The best place to make your voice heard is the "Product Feedback" board, where you can submit your ideas and share it with other members. The suggestions with more votes are taken into consideration by our developers for new updates or product development.
@voomdoon  I like Slashed face. It clearly shows the day and date on 1 line, the time on 1 line, and other stats below in smaller font. The battery %age is seen on the next screen down (ie, swipe up)rippled.fitbit.face.jpg
These don't specifically show the battery. I can find the battery percentage graphic but it's so tiny I can't really determine what the percentage might be better than lower half of charge or upper.
