04-30-2024 12:26
04-30-2024 12:26
I could swear that my prior Charge 5 displayed Heart Rate (along with Steps, Distance, and Calories) on the screen reached by swiping up from the Clock screen. My charge 6 displays Active Minutes instead.
Is there any way to change what is displayed there to replace Active Minutes with Heart Rate?
04-30-2024 13:04
04-30-2024 13:04
Hello @bkspero
I double checked and confirmed that my Charge 5 screen displays the same as what you're seeing on the Charge 6: Steps, Distance, AZM, & Calories. Unfortunately, there isn't a way I know of to switch Heart rate for AZM.
Since I wanted to keep track of my heart rate, I changed the default clock face on my Charge 5 to one that showed heart rate.
Check in the Gallery to see if there's a different clock face that you like which has heart rate. This article has the instructions on How to change the clock face (<-- click link)
04-30-2024 13:04
04-30-2024 13:04
Hello @bkspero
04-30-2024 15:38
04-30-2024 15:38
Thank-you, Rieko. Bummer, but it makes sense. That screen is called Daily Stats. It infers a summation of the daily numbers for the displayed parameters. Heart Rate is not a cumulative value, but an instantaneous one. So it doesn't qualify. Thanks, again.
The clock face I use allows selection of the parameter to display. So I can display heart rate there. I normally prefer displaying the day's step total, but I guess swiping 1 screen for that isn't too much trouble.
