Lost my Charge 6 in NYC
ANSWERED
Dear all,
If anyone found a Fitbitcharge 6 in Chinatown NYC today, please, please contact me.
I know I probably won't find it again. But maybe, just maybe.
Also, is there a way to lock the device to prevent from people using it?
1 BEST ANSWER
Accepted Solutions
Hi @LKCC - as @RiekoC  says there isn't a way to remotely lock it but you can always chat via the Fitbit App, Help & support section, Contact Customer support, they might be able to disable it.
However anyone finding it and wanting to use it would have to first buy a charger to continue to use it so it would disable itself after a while without one.
You could always check back with support after a week and perhaps they can tell you of any activity on the device.
10 REPLIES 10
Hello @LKCC
I'm so sorry to see that you lost your Charge 6.
There isn't a way to remotely lock the Fitbit that I know of. Perhaps someone else might have a suggestion.
BTW, I believe a person would have to do a factory reset if they wanted to use the device since the it's currently "tied" to your account.
Oh no!! So sorry. This is one of my Fears as I am absent minded/ have adhd, and tend to lose things very easily.  I would like to follow this thread to see any solutions in the case of a lost device.
GL!
Hi @BT6YY7 - see this link , it could be helpful
What should I do if I lose my Fitbit device?
@LKCC- just in case you didn't lose it where you thought, try the link too..
Thank you for your kind response. I hope they do have to do a factory reset. I wonder if I would get an email if someone tries to tie to another account or a reset?
Thank you for the advice. I looked through the help & support section. I'll try to chat with Fitbit.
I hope it'll never happen to you and never need to use this thread.
@LKCC - you won't get an email if someone tries to use or reset it.
The link works, try copying it and paste in a browser, or you may be protected from opening external links, in the email, so go to the topic in the forum in the browser and try the link.
@Guy_
Thank you. I meant I tried the link and used the bluetooth app, but my fitbit is nowhere to be found. lol 😞
@LKCC - lol, just in case the battery is already flat, you may have luck if you ask your dog to look for it the old fashioned way!
