08-23-2025 05:09
08-23-2025 05:09
I am a light sleeper and often wake up at least once during the night. Before the last firmware update in August 2025, I was able to delete short sleep sessions resulting in no sleep stages recorded and then manually log my entire sleep session to see a graph including sleep stages. . This process no longer works so I am unable to view my sleep stages.
08-23-2025 06:22
08-23-2025 06:22
Hi @Mjolaughl. This suggestion might or might not work for you. It sounds like you have at least one session that has sleep stages. Delete the short sessions. Then EDIT the session with sleep stages to cover your full time in bed.
I wake up, too. Sometimes I have to use the restroom. But I usually fall back asleep fast enough the I get one long sleep. I hope this helps.
Laurie | Maryland
