03-27-2025 01:18
03-27-2025 01:18
This morning I am unable to log yoga or pilates. Just not coming up in search.
Best Answer03-27-2025 09:42
03-27-2025 09:42
Hi @JulieC_M, thanks for stopping by, I hope you're doing well.
I'm happy to help you log your activity. If your search doesn't return any results, make sure your are typing an activity included in the list. Attempt to search an activity such as run. If you don't get any result, i suggest you follow these steps:
- First, force quit the app
- Restart your phone
You may also consider, clear your app's cache. To clear the cache for a specific Android app, navigate to your device's Settings > Apps > Select the app > Storage & cache > Clear cache.
Furthermore, make sure you are running the latest version of the Fitbit app. Refer to our help article How do I use the Fitbit app? > How do I update the Fitbit app?
Best Answer03-30-2025 01:07
03-30-2025 01:07
