06-27-2025
11:42
15:34
AndreaFitbit
06-27-2025
11:42
15:34
AndreaFitbit
I've worn a fitbit since 2019. Charge 5 in most of 2024 and charge 6 since December 2024. Before that I can't recall the type. Today I looked back to past years, and the app shows no sleep stage data in 2000, no sleep stage data in 2022, and none from Feb-Dec 2024. But data is present in 2019, 2021, and to date this year. During those times I can see the data for duration, score, and schedule, just nothing for sleep stages. Says 'No Data'. Seems like a bug of some sort?
Moderator Edit: Formatting.
Best Answer06-27-2025 13:10
06-27-2025 13:10
@rawlins02 Do you use an Android or iPhone? You are describing an app issue, usually limited to one platform, not both.
Your post can get moved to a better fit forum.
Laurie | Maryland
