11-28-2023
19:54
11:56
DavidFitbit
11-28-2023
19:54
11:56
DavidFitbit
I've had a Charge 5 (well, 6 of them to be precise, because they kept failing) for the past 20-odd months and now, to avoid getting stuck without a watch again, decided to purchase the Charge 6.
I learnt the hard way that you cant have more than 1 of the same model connected as your devices at the same time (e.g. can not have two Charge 5 on one account) BUT, you can have a different model, so when I upgraded from the Charge 2 (still working) to the Charge 5, I could keep both connected (that was a lifesaver when waiting for the replacements .... 5 TIMES!!!! )
So, why can I not add Charge 6 to my account? Instead, I am forced to 'REPLACE' the Charge 5 when going through the setup procedure.
I kind of get the feeling that the Charge 6 is really a 'fixed' Charge 5, to address all the quality issues rather than it being a generationally new device, more like a Charge 5.1
Is there any other explanation for this?
11-28-2023 20:19
11-28-2023 20:19
from the article - click to go there
Can I use more than one Fitbit device with the same account?
You can't connect multiple devices that use the Fitbit Gallery to one account. For Fitbit Charge series, Fitbit Inspire series, Fitbit Luxe, Fitbit Sense series, Fitbit Versa series, and Google Pixel Watch series, only connect one of these devices to your account at a time.
If you connect more than 1 Fitbit device to the same account, note the following:
11-28-2023 20:19
11-28-2023 20:19
06-17-2025 11:25
06-17-2025 11:25
I have the exact same issue
Best Answer06-17-2025 17:16
06-17-2025 17:16
Hello @spannoch
What issue are you experiencing?
If you're trying to have 2 Fitbit devices on the app, the Best Answer from 2023 still applies.
06-17-2025 18:22
