01-09-2025 20:51
01-09-2025 20:51
Does anyone know why my 1 year old charge 6 says I'm burning 12,000 calories per day. I way like 45 kilograms which is standard for my age but if I actually burned that much I would be dead
Any know how to help?
01-10-2025 07:33
01-10-2025 07:33
If fitbit thought your weight was 450 kg instead of 45 kg, it would take a lot more work to get through your day. I couldn't begin to say how much of a difference, but I have seen people whose calories were way off, and then discovered they had accidentally entered their weight wrong. I would think it would be easier just to check your weight entry rather than to discuss how much difference it would make, but it's up to you.
01-09-2025 21:16
01-09-2025 21:16
First thing, check your weight is entered correct, no off by a decimal point or such.
01-09-2025 21:28
01-09-2025 21:28
01-10-2025 07:33
01-10-2025 07:33
01-13-2025 21:01
01-13-2025 21:01
Thanks that really helped. You were right that I had entered my weight in wrong. Thank you so much
